WTB: Shifter and other Transmission hardware, Flywheel?
Hello, new member here. I don't own an s2000, however, I recently began piecing together a swap for an older corolla and need a few small things. Ill continue to edit and update this with parts as I continue. I bought a used 6sp transmission from someone, but it is pretty bare. Im needing parts like the shifter any kind is fine aftermarket or oem, clutch fork, and any hardware that might accompany(this includes and is not limited to clutch mounting hardware, clutch fork/throwout bearing hub(if applicable), block-side bell housing bolts, and anything else you think I might need. Please let me know if you might have anything and your prices shipped to 32825, im trying to beat the ebay and local "distributor" prices. Thanks!
I could also use a flywheel, but it isnt priority right now as I havnt decided if to go with a stock ap1 or pay the extra for a 10lb.I dont really want to go any lower than 10lbsbecause it will still be dailyed. Im not 100% sure if the 3-4lbs of savings between oem and lightened would be worth the added cost. |
Have an AP1 flywheel for sale. 36K miles.
