'02+ NSX wheels on S2000?
Old Feb 13, 2007 | 07:02 AM
X4DLuvOfSpeedX's Avatar
Default '02+ NSX wheels on S2000?
I KNOW this has been asked before, and I even had a pic of a sebring with '04 wheels for a desktop, but now I can only find info on the older NSX wheels. I'm talking about the 2002-up 17" wheels.
Specs:
Size: 17x7 front, 17x9 rear
Offsets: 55 mm front, 56 mm rear
Centerbore: 70(.1) mm front, 64(.1) mm rear
Will they fit? I think the rears are a tight fit. What does it take to make them work? What tire sizes should I put on? I'm also planning on lowering the car around 1".
Also, anyone know how much they weigh?
Thanksssss
Old Feb 13, 2007 | 08:01 AM
To answer my own question, sounds like the fronts will stick out a hair too much? Can anyone confirm this?
Thanks.
Old Feb 13, 2007 | 08:06 AM
Fubawu's Avatar
No the fronts should be fine.
Old Feb 13, 2007 | 08:18 AM
Yeah, I guess you're right. Stock AP2 wheels are pretty much the same dimensions: 17" x 7.0", +55 offset, 215 tire (from the wheel fitment guide thread). They even have the same centerbore. If only I could find out if the NSX wheels clear the S2000 calipers...
Old Feb 13, 2007 | 08:24 AM
Fubawu's Avatar
Do you have a set in mind? They are pretty pricey used??
John
Old Feb 15, 2007 | 12:55 PM
S2kPerez's Avatar
i would like to know also i found a web site fornsx wheels i wanted to know if the 02-04 will fit or do i need to go with the 94-01 model on my 2001 s2k?
Old Feb 15, 2007 | 02:33 PM
Fubawu's Avatar
Are those reproduction replica's?? Those will fit. offset I think is +55 front and 65 rear? If I remember right
John
Old Feb 15, 2007 | 04:45 PM
silentdancer's Avatar
all of those will fit except for the 15inch nsx rims which dont clear the caliper.
with this set up = 17x7 front, 17x9 rear
you can run
215/245
94+ wheels fit the S
Old Feb 15, 2007 | 07:09 PM
Aze85's Avatar
you can run
215/245
would you be able to run any wider if you are not dropped as much.
