S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   Wheels and Tires (https://www.s2ki.com/forums/wheels-tires-56/)
-   -   15mm Spacer Question. (https://www.s2ki.com/forums/wheels-tires-56/15mm-spacer-question-770478/)
fishs2000 Mar 3, 2010 12:02 PM
Ok, im promise this is the last thread about spacers from me.
Is there a 15mm hub centric spacer with integrated studs that can be installed WITHOUT having to shave down the stock studs?
I have stock AP2 V1's and the back hubs have a rather large deep slot in them.
2nd part:
Lowered with maybe a finger gap all around, will I need to roll my fenders with stock tire sizes with 15mm up front and 20mm out back?
Thanks in advance for the help guys.
Jim@tirerack Mar 3, 2010 12:43 PM
I do not have anything available. With the stock wheels and tires I would say you should not have to roll the fender lips.
1nate7 Mar 3, 2010 03:27 PM
2nd part:
The brand of spacer won't make any difference on clearance. If the slots are at least 10mm deep in the wheels then you are good to go. I don't believe H&R makes a bolt on 15mm spacer though, so you would have to go with Kics/Ichiba/etc.
© 2026 MH Sub I, LLC dba Internet Brands
