17x8 +47f 17x9 +63r
Old Oct 12, 2005 | 02:40 PM
spoiled@21's Avatar
Default 17x8 +47f 17x9 +63r
see title. the rears I know will work but how about the front?
Old Oct 12, 2005 | 02:55 PM
trivium's Avatar
Banned
They are only 1-2 mm off. Should'nt be an issue.
Mind you, the amount of drop, tire size, and camber degree should be taken into account.
Old Oct 12, 2005 | 03:37 PM
spoiled@21's Avatar
1.2 inch drop. 215/45/17fr and -1.25 camber on each wheel. I run a little over -2 in the back but those are not an issue.
Old Oct 12, 2005 | 03:59 PM
trivium's Avatar
Banned
I am going to go on a limb and say that you should have no problem.
You should get a second (or third) opinion just to be safe.
Old Oct 12, 2005 | 09:17 PM
spoiled@21's Avatar
cool. second opinion please
Old Oct 13, 2005 | 06:04 AM
aggie's Avatar
Looks good, 215 is best for front but some 225s might fit too. 255 rear obviously
Old Oct 13, 2005 | 12:26 PM
spoiled@21's Avatar
thanks,
Old Oct 13, 2005 | 03:11 PM
HvRRZ's Avatar
you should be able to run 225's in the front with no probs I think. If you go wider in the back then you cn always go something like 265 or 275/ 35's. should work aswell.
Old Oct 14, 2005 | 09:43 AM
SIIK2NR's Avatar
225's up front with a signifigant drop will rub on hard corners and dips. 215's in the front no problems....... unless you are running 255 or 265's in the rear which will result in understeer at high speed cornering.
Old Oct 14, 2005 | 09:45 AM
spoiled@21's Avatar
215/255 is the same relationship as 205/245
why would that understeer more than stock?
