17x9 17x10 6ULR
17x9 +63. 255/40 RE01R. -3° front camber, -2.6° rear. Stock fenders. As predicted, the rears clear everything fine. The front wheels touch the control arm just at full lock with race alignment. With a milder street alignment, the top edges of the tires are closer to the fender and the wheel clears the control arm a bit better.
Originally Posted by epicanthal,Feb 5 2010, 04:59 PM
I don't want to roll, so 17x10 +72 or 17x9 +63 w/275 width in rear? I can't afford lowering and these at same time, so I'm thinking just the wheels with stock spring/damper for now. I'd like to stay staggered, but looking for suggestions. I'd like a setup that won't require fender roll now or with coilover drop later.
Can I consider either of these combinations or does 275 in rear automatically put me in fender roll territory?
1) 17x9 +63 w/255 front and 17x10 +72 w/275 rear
2) 17x9 +63 w/255 front and 17x9 +63 w/275 rear
Originally Posted by 949Racing,Feb 7 2010, 05:29 PM
Option 1 is the way to go.
From your comments over in the racing forum..."17x9 +63. 255/40 RE01R. -3° front camber, -2.6° rear. Stock fenders. As predicted, the rears clear everything fine. The front wheels touch the control arm just at full lock. With a milder street alignment, the top edges of the tires are closer to the fender and the wheel clears the control arm a bit better. Race alignment has more control arm contact just like our 15" 6UL on the Miata ."
Originally Posted by Cheers!,Mar 3 2010, 04:17 PM
949: That isn't a s2000 with stock suspension you have your wheels mounted is it?
