17x9 +40 TE37
Old Sep 17, 2015 | 04:24 PM
blueprint's Avatar
Default 17x9 +40 TE37
Hey guys. 17x9 +40 TE37. Whats it gonna take to get them to fit on a stock body with rolled fenders/tab relocated and -3 camber.
Thanks!
Old Sep 17, 2015 | 04:31 PM
Ricky_Flowers_'s Avatar
Five lug nuts per wheel.
Old Sep 17, 2015 | 04:32 PM
Jk, lol. That's a pretty standard offset for that wheel. Bunch of peeps on the forums run them. Just roll your fenders so they don't rub. 3 degrees of camber is more than enough.
Old Sep 17, 2015 | 05:42 PM
s2000Junky's Avatar
Thanks!
Depends on the tires you run. The rear will accommodate a 255 with your list, however the front wont without a pretty serious pull. You can run a 245 up front with less pull, or settle on a 225/45 or possibly a 235/40 if you want to try and avoid it.
Old Sep 17, 2015 | 06:08 PM
blueprint's Avatar
Was hoping to get away with running a square set with 255/40/17 RS3....
Old Sep 17, 2015 | 06:22 PM
I would run a 255 ZII. They run a little narrower than the RS3. You could do either, but you're gonna need a good amount of camber and a pretty good pull. It's absolutely doable, though, I've seen it.
Old Sep 17, 2015 | 06:42 PM
blueprint's Avatar
Spoke to a few local guys with this spec. I can get away with the RS3 and 255's. I'll post results.
Old Sep 17, 2015 | 06:46 PM
s2000Junky's Avatar
Sure if you are ok with pulling the front fenders as mentioned.
Old Sep 17, 2015 | 07:00 PM
blueprint's Avatar
Im not willing to pull the fenders... But after speaking to the locals i wont need to. I'll test fit them tmrw.
Old Sep 17, 2015 | 09:29 PM
s2000Junky's Avatar
Good luck with that, I hope your not lowered at all. Send pics when you do.
