17x9 +63 in the front
Old Jan 19, 2006 | 08:19 PM
nas2k111's Avatar
Default 17x9 +63 in the front
will 17x9 +63 rim with a 255/40/17 tire in the front rub with a 1-1.5 inch drop?
Old Jan 19, 2006 | 09:53 PM
smracer31's Avatar
you may rub but it should not stick out past the fender. What width are you running in the rear? if your running 9 in the front i would not go any lower in the rear. go staggered to a 10 or a 9 all around.
Old Jan 20, 2006 | 07:46 AM
nas2k111's Avatar
same size rims and tires all around
Old Jan 20, 2006 | 08:34 AM
Castor's Avatar
www.maxrev.net
has extensive article on running non-staggered.
Old Jan 20, 2006 | 08:40 AM
bluesaint's Avatar
if you plan on running spoon bbk, stoptech bbk, endless bbk, etc... then that offset will not clear. You'll need to run spacers.
Old Jan 20, 2006 | 09:28 AM
spa-zz's Avatar
Originally Posted by Castor,Jan 20 2006, 12:34 PM
www.maxrev.net
This one?
http://www.maxrev.net/index.php?location=widetires.htm
Looks like it can be made to work OK, with some caveats.
Old Jan 22, 2006 | 02:01 PM
deepee's Avatar
a lot of track cars use this set up. 17x9 all around. If you rub, you might could get away with rolling the fenders. anything more than 1" drop might be too low assuming that you'll be doing some hard cornering with this set up.
Old Jan 22, 2006 | 02:14 PM
turbo_pwr's Avatar
I'd almost be willing to bet my next kid that will rub. I think you need to go around 235 for it not to rub.
Old Jan 22, 2006 | 02:48 PM
smccurry's Avatar
[QUOTE=turbo_pwr,Jan 22 2006, 01:14 PM] I'd almost be willing to bet my next kid that will rub.
Old Jan 23, 2006 | 04:19 PM
maxrev's Avatar
255/40/17 on +63 17x9 volks will rub away your plastic fender lining clips. I removed all the plastic clips on the fender but it still chewed up the fender linings. I will probably need to buy new fender linings when I sell my car.
I will recommend using a coilover with high spring rate (Track-focused) and maxed out camber (-2.0 or more) if you run this setup.
As you can see, my car is fairly low and it did not rub at all on a worn down RA1 in 255/40/17 size and I have not rolled my fender.
The car will have more grip up front and you will need to change your driving style to induce understeer and use the extra grip up front to your advantage. (braking, cornering)
Note: If your running OEM stock suspension, the volks will run your front a-arm if you turn the wheel all the way either direction.
