18" 8.5 wide and +40 on S2000?
Old Oct 30, 2012 | 11:19 PM
tim512's Avatar
Default 18" 8.5 wide and +40 on S2000?
I'm' getting a Volk SE37K 18x8.5 ET40. Would it be ok for me car? What should be the tire size?
FromaDB2toanAP1's Avatar
18x8.5 all around?
Old Oct 30, 2012 | 11:25 PM
tim512's Avatar
yes 18 x 8.5 all around
Old Oct 30, 2012 | 11:37 PM
245/35/18 in the back will be ok with some camber, won't rub, but the front, you will rub with the same size tires...if you don't want to roll, I guess you can go with 215/40/18, but it will be stretched.
Old Oct 30, 2012 | 11:39 PM
tim512's Avatar
Thank you very much. By the way, is 8.5 in the rear enough? I plan to get a SOS supercharger too
Old Oct 30, 2012 | 11:51 PM
tim512's Avatar
wait. I'm confused. since my wheel is 18. shouldn't it be 215/45/18 and 245/40/18?
Old Oct 31, 2012 | 01:31 AM
Oops my bad, 245/35/18 and 215/40/18. 8.5 in the back is ok, but 9 seems to be the standard.
Old Oct 31, 2012 | 03:54 AM
S2k007's Avatar
I wouldn't run anything smaller than 225 on a 8.5inch wide wheel.
Old Oct 31, 2012 | 05:35 AM
JohnsS2000's Avatar
I am running 18 x 8.5 and have 225/40/18 tires on all 4 corners. Not stretched at all, no rubbing but I am on OEM suspension
Old Oct 31, 2012 | 05:42 AM
tim512's Avatar
Maybe i should just go with TE37 17" 7.5 +40 8.5 +40 with 215/45/17 and 245/40/17. What do you guys think? I'm installing kw v3 suspension.
