S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   Wheels and Tires (https://www.s2ki.com/forums/wheels-tires-56/)
-   -   18x7 / 18x8 , HELP - please (https://www.s2ki.com/forums/wheels-tires-56/18x7-18x8-help-please-296727/)
miralem Jun 8, 2005 06:40 AM
Help PLEASE
would this fit ? .....car has -1" drop
front 18x7 +40 with 215/40/18
rear 18x8 +40 with 235/40/18
Thanks
SolReborn Jun 8, 2005 08:30 AM
Both need to be bigger... but especially the rear
l8brakr Jun 8, 2005 09:54 AM
Front is close and the rear is very marginal. With an aggressive alignment you might be ok but don't hold me to it ;) The choice of tire size will probably keep you safe but beware the limited amount of stagger is not ideal.
miralem Jun 8, 2005 10:11 AM
thanks l8brakr,
i'm going to try this !!!!!
aggie Jun 8, 2005 10:38 AM
Your rear wheel face will move out about 1.2" per side from stock 16".
miralem Jun 8, 2005 11:17 AM
aggie,
according to "some" calc's -
rear wheel face should move out about 18mm. (less then 3/4")
................correct me if i'm wrong !!!!!!!!!!!
l8brakr Jun 8, 2005 07:49 PM
31.35mm to be exact (1.23") That is 17mm more than my set up and from looking at my car it should put the rim right at the outside edge of the fender. Like I said I think the 235 tire and an aggressive alignment are the only things that will keep it from rubbing. Hopefully you're getting these for a good price and can dump them if needed. BTW, what wheels are they?
Ubetit Jun 9, 2005 05:07 AM
I don't think even the small tires and aggressive alignment will save you from rubbing. What wheels? Post some pics when you get them.
miralem Jun 9, 2005 10:06 AM
i got them very cheap :-)....... so i'm planning to do some work on my fenders........( i mean my friend will )
- he did it to his M3 ..........looks good
wheels are TSW Catlunya..............
miralem Jun 16, 2005 05:43 AM
here you go , some pics
[img]http://www.dotphoto.com/MemViewImage.asp?AID=2535735&IID=81762815&INUM=2&I CT=9&IPP=24[/img.]
[img]http://www.dotphoto.com/MemViewImage.asp?AID=2535735&IID=81762735&INUM=1&I CT=9&IPP=24[/img.]
or check out more ...
http://www.dotphoto.com/MemViewAlbum.asp?AID=2535735
© 2026 MH Sub I, LLC dba Internet Brands
