S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   Wheels and Tires (https://www.s2ki.com/forums/wheels-tires-56/)
-   -   18X7.5 ET40 ? (https://www.s2ki.com/forums/wheels-tires-56/18x7-5-et40-833050/)
jetmagnum Dec 2, 2010 10:03 AM
18X7.5 ET40 ?
ANYONE HAVE ANY EXPERIENCE RUNNING THIS SIZE? IF IT WILL WORK, ANY TIRE SUGGESTIONS? WANT TO TRY TO RUN THIS SIZE ALL AROUND-SOMEONE GAVE ME THE RIMS.
SORRY IF THIS IS A "SHOULD KNOW ALREADY" SITUATION.....IM NEW HERE.
THANKS IN ADVANCE FOR ANY INFO!
Jim@tirerack Dec 2, 2010 10:07 AM
First off make sure the wheels have different center bores. I would say the best fit would be maybe a 215/40R18 front and 225/40R18 rear.
jetmagnum Dec 2, 2010 10:17 AM
OK GREAT, WHAT SHOULD THE CENTER BORES BE?
THEY ARE ALL THE SAME
jetmagnum Dec 2, 2010 10:24 AM
BORE MEASURES 72.62MM ON ALL FOUR
hrpfg2 Dec 2, 2010 01:15 PM
or 2 of them can be 64mm for the rears
jetmagnum Dec 2, 2010 04:45 PM
i can get hub rings to match sizes.
what are the actual bore sizes front+rear?
s2sik Dec 2, 2010 11:14 PM
easy on the caps man :D
7.5 is a bit narrow in my opinion for the rear. at least go 8.5 to spec with ap2 width
1nate7 Dec 3, 2010 04:44 AM
70.1 mm front hub, 64.1 rear hub. IMO I would be more concerned about running a 7.5" rear although you could squeeze a 245/40 on there.
© 2026 MH Sub I, LLC dba Internet Brands
