18x9.5 +45
Old Dec 12, 2012 | 08:45 AM
kwunap2's Avatar
Default 18x9.5 +45
I have a question guys, I'm looking to get a set of sbc rpf1 in 18's but I'm not to sure if they will fit can somebody help me out and let me know if they will or will not fit? 18x9.5 +45 all around
Old Dec 12, 2012 | 08:51 AM
Dreaming_S2k's Avatar
Sure why not. Just do the proper fender work.
Old Dec 12, 2012 | 08:57 AM
Manga_Spawn's Avatar
Site Moderator
Yup. You will need a good fender roll, bumper tab relocated, and a good alignment. At least 2 degrees of camber all the way around. You should be able to run either 245/35/18 or 255/35/18 all the way around.
Old Dec 12, 2012 | 09:32 AM
kwunap2's Avatar
Ok thanks, i seen the nt03 in the same size but different offet which was +40 . Is that a big difference between +40 and +45 ?? Do you have to run more camber then the other?
Old Dec 12, 2012 | 10:08 AM
s2000Junky's Avatar
Yes you will need to run more camber at +40. Id stick with the +45 as its more versatile with alignments and tire options, but still look flush if that’s what your after.
Old Dec 12, 2012 | 10:34 AM
kwunap2's Avatar
What size can I run for a flush look? 235/40 ?
Old Dec 12, 2012 | 10:43 AM
s2000Junky's Avatar
No I wouldn’t recommend that size. The recommendation previously of 245/35 or 255/35 are good fitment options. The 245 will be stretched quite a bit, the 255 still some stretch. I would not go any less then 245 on a 9.5" wheel.
Old Dec 12, 2012 | 11:05 AM
Site Moderator
Sigh I had hope you were actually on the right track and not trying to have a hellafail stretched tire. A 245 is already going to be stretched on a 9.5 inch wheel. I would actually suggest running the 255 all the way around but you could have a 245 in front to help with fitment. Anything narrower is not recommended.
Rays S2k
Sep 13, 2013 09:30 AM
clarkster009
Sep 9, 2013 09:14 AM
aznvietboy725
Mar 24, 2012 01:47 AM
Kyukca
Aug 4, 2011 12:59 PM
stwokayyy
Mar 12, 2010 11:18 PM
