19 inch wheels
Old Jan 30, 2015 | 08:14 PM
J0E's Avatar
J0E
Default 19 inch wheels
I'm thinking of getting the new 19 inch work cr 2 piece emotions, but don't know what sizes I need and the offset. Right now I have xxrs 18 x 8.75, and I sit extremely low, run almost everything.
So what would I need to run with them? I was thinking 19 x 9 and 19 x 10 in the back but not sure on the offset and if I'll need camber or not, thanks!
Old Jan 30, 2015 | 11:08 PM
Bullwings's Avatar
A different car...
Old Jan 31, 2015 | 04:55 AM
jst2878's Avatar
^^ x2
Old Jan 31, 2015 | 05:16 AM
Eriasu's Avatar
you could PM Stena. Here's his thread about 19inch ce28's. https://www.s2ki.com/s2000/topic/111...-on-the-s2000/ running 19's on our cars is generally a bad idea and looked down upon.
Old Jan 31, 2015 | 06:40 AM
clarkster009's Avatar
A different car...
Old Jan 31, 2015 | 08:05 AM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Originally Posted by clarkster009
Originally Posted by Bullwings' timestamp='1422691710' post='23488341
[quote name='J0E' timestamp='1422681272' post='23488246']
A different car...
[/quote]
Old Jan 31, 2015 | 09:47 AM
d1000rr's Avatar
Need more detail on your current suspension setup and your fender situation.... but the closest you'll get to fit your car if you want the Work Emotion CR 2P will be:
19x8.5 +42 Front
19x10 +57 Rear
The rear will be ok but the fronts will be super aggressive (pull, roll, camber).
Old Jan 31, 2015 | 11:31 AM
Redline S2K's Avatar
Whats with the sudden flood of people wanting 19's?
Old Jan 31, 2015 | 03:37 PM
J0E's Avatar
J0E
I didnt want 19's. But i like the CR 2 piece emotions over avant gardes since they are cheaper.
I am currently running megan street coil overs. closes to maxed out. Front fenders are going to be replaced and re rolled. I am fine with running aggresive camber in the front. Currently on the xxrs 18's in the front i rub when i turn the wheel all the way each way. The back rubs when the suspension bottoms out and scrapes the rim.
Old Jan 31, 2015 | 03:43 PM
s2000Junky's Avatar
Cool...
