S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   Wheels and Tires (https://www.s2ki.com/forums/wheels-tires-56/)
-   -   2001 rear wheels to the front? (https://www.s2ki.com/forums/wheels-tires-56/2001-rear-wheels-front-429653/)
jon3501447 Oct 10, 2006 11:32 PM
I have a 2001 S2K and kinda like the stock wheels. However I hate that the front wheels are only 6.5" wide...it really limits the tire options. With the rear wheels being 7" I've contemplated getting rear wheels and putting them up front. Has anyone tried this? Or perhaps insight as to the feasibility of doing this( Such as, is the backspacing to far off to properly fit within the body lines)?
SpitfireS Oct 10, 2006 11:59 PM
First : this is a "Wheels & Tires Forum" question.
Wheels & Tires Forum Link
Second : Honda designed the S2000 with wider wheels at the rear for a reason.
https://www.s2ki.com/forums/index.php?showtopic=428946
Third : the OEM rear wheels won't even fit at the front because the hub diameter is too small (64mm. with the front hub being 70mm.)
:hello:
CoralDoc Oct 11, 2006 03:14 AM
I'll reiterate #2 - it is not worth upsetting the correct balance of the car for an aesthetic preference.
Regarding #3, you could have the rear wheels machined to accommodate the swap. AP1 wheels are inexpensive enough to make it worth doing, except for that pesky #2 problem.
floridawriter Oct 16, 2006 01:15 PM
The rear wheels will not fit on the front hubs.
© 2026 MH Sub I, LLC dba Internet Brands
