S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   Wheels and Tires (https://www.s2ki.com/forums/wheels-tires-56/)
-   -   245/40/18 rears (https://www.s2ki.com/forums/wheels-tires-56/245-40-18-rears-797634/)
lzybum Jun 21, 2010 08:30 AM
245/40/18 rears
apart from it being off the speedo and the sidewalls a bit tall, is there anything wrong with running 245/40/18 on the rears? possible braking failure etc... ?
according to tire calcs, its like an 25mm increase in rolling diameter when compared to ap1 size (R:225/50/16?).
lzybum Jun 22, 2010 01:19 AM
anyone?
alexisthemovie Jun 22, 2010 11:50 PM
Nothing, I am running 245/40/18 all around right now on 18x9.5's and they feel great.
//steve\\ Jun 23, 2010 05:39 AM
It's a tall tire but you'll be fine. Just watch your speed. At highway speeds you'll easily be going 5+ mph faster than your speedo says. If you normally drive fast sometimes that's just enough to get you pulled for speeding when you don't think you are.
[DT] Jun 23, 2010 06:28 AM
What size (width) wheel? If you're running a 9" or wider, I'd go with a 255 in a 35 profile. That's what I'm running with a 225/40 front.
Jim@tirerack Jun 23, 2010 12:56 PM
There is something wrong with that size. They are taller than the OE tires and will throw off the speedometer, odometer and gear ration. With the 225/40R18 on the front and the 245/40R18 rear you can also mess up the anti lock brakes.
lzybum Jun 24, 2010 03:04 AM
if it means anything,
im running 17/18 combo
F: 215/45/17 on 9"
R: 235/40/18 over 9.5"
and want to run if possible R: 245/40/18"
i didnt want to increase the width for the front as i want clearance for my fenders and didnt want to go down on profile as i dont want to lower the car anymore to fill in the wheelgaps.
with 235/40/18's the sidewall looked a tad shorter than 215/45 which is why im asking about 245/40/18's instead.
any possible recommendations for some 17/18 combo tires?
Rubn1out4GudLuk Jun 25, 2010 09:47 AM
Originally Posted by [DT
,Jun 23 2010, 07:28 AM] What size (width) wheel? If you're running a 9" or wider, I'd go with a 255 in a 35 profile. That's what I'm running with a 225/40 front.
:iagree:
© 2026 MH Sub I, LLC dba Internet Brands
