4 AP2 rears, maybe one set widened to 9.5"
Old Jan 7, 2008 | 07:07 PM
stantaur's Avatar
Default 4 AP2 rears, maybe one set widened to 9.5"
Anyone familiar with wheels from a site linked below called Wheels and Caps? If their weight, materials & finish is the same as AP2 OEMs, I'm interested in having them sent off to a company that widens the rims into a fitment that I want. Wanting to run 245 or 255 up front and 275 or 285 out back for auto-x.
Replica Rims
Weldcraft Wheel Widening
Definitely welcome thoughts / experiences / recommendations for the wheel company and any experiences with the wheel fitment.
Fitment is 1.5" wider than AP2 stock front and 1" wider rear. The rear width increase is at the inboard side of the wheel, meaning offset increases to ~ 67.7 and 77.7 (from the stock 55 and 65, since offset is measured from the now different centerline to the inner face of the wheel).
At $150/wheel for widening, I may try to save $300 of widening if I order four rears and have the pair I plan for the front get the bores increased to fit the front hub bore. Otherwise I could do a pair of fronts (17x7 and have them widened to 8 if 8.5 width / 65 offset was too wide)
That makes ~ $1025 (+ $75 shipping from the wheel widener = $1100) for widths that allow me to run 245 or 255 front and 275 or 285 rear on a 17" wheel. Not the lightest solution, but probably the most offset I can find to keep everything tucked into the wheel wells. Otherwise I'm looking at $2450 from CCW for these widths and approximate offsets.
Definitely welcome the thoughts & experiences. BTW, I'm running a fairly healthy turbo setup for SM2 autocross (torque peak = 4700 RPM), which is why I'm looking for this setup. 17s cost less than 18s, which is the reason I'm leaning toward 17s.
Thanks,
Stanford
Old Jan 7, 2008 | 09:53 PM
chairmnofthboard's Avatar
I was going to say "you're crazy" but I was wrong. pretty cool that they can do that to stock wheels.
Old Jan 7, 2008 | 10:42 PM
GrandMasterKhan's Avatar
i had thought about that actually. Definilty would be a sweet sleeper look to while your at it!
BTW if you run 5mm spacers all the way around then you can run the rears on the front w/o needing to modify the center bore.
Old Jan 7, 2008 | 11:04 PM
nitewing117's Avatar
Wow thats pretty cool how they can widen wheels on the back and front. It doesnt sound like a bad idea. My only concern is the quality of the replicas, but other than that it sounds great.
Old Jan 8, 2008 | 09:39 AM
lYellowDragonl's Avatar
pretty crazy i must say
Old Jan 8, 2008 | 11:02 AM
nearwater4me's Avatar
Sounds good, but will it be durable enough?
Wheel/tire failure can be catastrophic.
Dan
Old Jan 10, 2008 | 12:42 PM
dead-bird's Avatar
Are you doing this?
Or someone you know...
Old Jan 10, 2008 | 10:32 PM
Willie Gee's Avatar
I understood that you can run a 245 up front on regular AP2 wheels. It will be a bit pinched but it will work. 275s will fit on the rear.
Old Jan 11, 2008 | 03:40 AM
apautosport's Avatar
Originally Posted by dead-bird,Jan 10 2008, 01:42 PM
Are you doing this?
I would like to know also
Old Jan 11, 2008 | 08:35 PM
street_ruler's Avatar
so i just posted something about something similar to this before.
with that difference going wider by .5in so there is going to be a total of what...12.2+30mm stock difference you are going to ahve a car that really likes to plow. ap2's are notorious for not oversteering natrually. but as an autocrosser im sure you know this.
it seems cool but im wondering if its really worth it to just have a stock looking wheel that is wider...yah its unique but wouldnt you be better off with a lighter wheel that could just be purchased no custom work needed?
qiqin
Aug 8, 2009 02:49 AM
DonJ
Apr 29, 2009 02:12 PM
VitaRenovatio
Apr 12, 2009 04:10 PM
stantaur
Jan 8, 2008 07:25 AM
stantaur
Jan 8, 2008 04:27 AM
