57DR Tires & Wheel Size
Im looking to run Gram Lights 57DR but i want to run a 275 tire in the back and 225 or 235 in the front, what size wheels should I get?
Im willing to roll my fenders, my S is already dropped about an inch. |
Wont be possible without flares due to their offsets.
Yeah the widest tire you could run with the offsets available is a 255 in the rear. Pretty easy to fit the 17x9 +38 in the rear with the standard roll and tab relo and alignment. The. Get the highest offset 8 or 8.5 wide wheel needs to be above +35 for it to have a chance in the front.
I just got a set of 57DR's. I am running 17x9+38 Square. 225 in front & 245 in rear. My car is only dropped an inch or so, but it still required moderate camber settings to fit safely. If you want to run these wheels with more rubber in the front, you are going to need some wider fenders.
Originally Posted by JamesFM
(Post 23165376)
