5zigen FNO1R-C
Old May 16, 2005 | 06:47 PM
S2kAllStarDrifters!'s Avatar
Default 5zigen FNO1R-C
Ive been looking for the 5zigen FNO1R-C wheels black with polished lip, and finally found one, the offset is as follows
front 17x7.0 offset 48mm bolt pattern 5-x114.3
Rear 17x8.0 offset 43mm bolt pattern 5x114.3
What kind of tires as far as szie would you guys recommend without having any rubbing issues?..im also planning to drop the car by at least an inch..any advice would be deeply appreciated..Thanks guys!
Old May 16, 2005 | 07:46 PM
lil help guys..please
Old May 16, 2005 | 09:01 PM
SIIK2NR's Avatar
Wrong offsets.....your going to rub in the rear...
Old May 17, 2005 | 05:30 AM
what should be the correct offset for these wheels? thanks
Old May 17, 2005 | 07:25 AM
SIIK2NR's Avatar
OEM offsets are:
+55 front
+65 rear
The smaller number on the offset......the more it's going to stick out from the wheels well.
Your intial question had +43 in the rear which is 22mm off the OEM offset.
22mm equates to about 1 and 3/8 inches.
Old May 17, 2005 | 07:43 AM
ASMspec's Avatar
You can get away with those offsets for daily driving/commuting. They are fine.
Run a 215/45/17 front tire Toyo T1S tire
Run a 235/40/17 rear tire Toyo T1S tire
You may be able to squeeze a 245 on there if your not that lowered. It may rub though.
Good luck.
Old May 17, 2005 | 08:26 AM
esracer's Avatar
there was a guy on this forum that was running the same as you are talking about but 43 offset in front and 48 in back, he was lowered an inch on Eibachs and said he did not rub, 225 tires in front 245 in back
Old May 17, 2005 | 08:28 AM
ASMspec's Avatar
See there you go. They should work.
When I meant lowered I meant a minimum of a 2.5-3 inch drop front and rear.
Old May 17, 2005 | 08:30 AM
esracer's Avatar
lolol yeah that is a DROP not everyone drops their stuff that low
Old May 17, 2005 | 01:36 PM
Good luck.
Hey man..thanks a lot I really appreciate that!
