S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   Wheels and Tires (https://www.s2ki.com/forums/wheels-tires-56/)
-   -   Advice on Tires/Size ... Please ... (https://www.s2ki.com/forums/wheels-tires-56/advice-tires-size-please-814044/)
Stretch21 Sep 2, 2010 03:10 PM
I did some research first but couldnt find anything that answered my question without creating new ones.
I just picked up a set of FN's 17x9 +43 all around. I am considering tire sizes and here's where I am at this point.
1.) Car is stock height now but will be lowered with coilovers appox 1-1.75 in.
2.) I am willing to roll
3.) NOT willing to flare
4.) Will take some neg. camber but nothing crazy
What then is the best tire size to run?
My number one contender is F:215-40 R:235-40
Mainly to avoid rubbing, cutting, flaring, or too much negative camber.
Opinions please ... if you think bigger, more profile, or all same, all will be considered.
JDMQuip Sep 2, 2010 03:31 PM
215 on a 9" rim I would not recommend. If you're not planning to track the car you could go with a 225F and 245R. However with those offsets I can't guarantee you won't rub without a very small fender flare up front.
If you plan on tracking the car, I'd go with 255 all the way around.
Jim@tirerack Sep 4, 2010 09:47 AM
If you really are looking to avoid rubbing I would suggest another wheel. I think that the fender lip roll and the most negative camber that Honda recommends would make the wheel doable. I would suggest no less than a 225/45R17. The 215/45R17 is not going to work on the 17X9 wheel correctly. The 235/40R17 ends up being about 1/2" shorter than stock.
If I can help with the tires let me know.
S2000RS Sep 7, 2010 05:02 PM
[QUOTE=JDMQuip,Sep 2 2010, 03:31 PM]215 on a 9" rim I would not recommend. If you're not planning to track the car you could go with a 225F and 245R.
Jim@tirerack Sep 8, 2010 06:51 AM
S2000RS, I would need to know what size and offset the wheels you are looking at are. Let me know and I can recommend tire sizes.
alexisthemovie Sep 8, 2010 11:25 AM
Go with a 235/40 or 245/40 all around, or if you'd prefer an easier fit, then 245/225 stagger. A simple roll with relocated bumper bolt is enough. Those wheels are only 2mm more aggressive than the common 17x9 +45 RPF1 setup.
© 2026 MH Sub I, LLC dba Internet Brands
