alignment
Hi Guys,
I did some research on the alignment and a lots of you saying that Euro Spec Alignment are better than stock one.... I did my alignment 2 months ago... It say on my report that I only can go 6 degrees 3" max on my front right left caster... but the euro spec require 6 degrees 45"... so what happen now? will my car get to the euro spec alignment?
Why on my last alignment report I got right caster and left caster got diferent #?
And Euro spec are the following:
Front Caster is 6 degrees 45"
Front Camber is -1 degree 00"
Front Toe is 0 degree 00"
Front Total Toe is 0 degree 00"
Rear Camber is -2 degree 00"
Rear Toe is 0 degree 0"
Rear Total Toe In is 0 degree 40"
my previous alignment
Front Caster Right is 6 degrees 7"
Front Caster Left is 7 degrees 2"
Front Camber is -0 degree 5"
Rear Camber is -1 degree 5"
Rear Toe Right is 0 degree 40"
Rear Toe Left is 0 degree 40"
Rear Total Toe In is 0 degree 80"
