am i gonna die?
so a brief introduction to my situation:
Im unemployed and stuck with my s2000. its paid off, so its not bleeding money out of me but has a few problems which would make me lose my shirt if I absolutely needed to sell it.
It snowed yesterday and i had to drive my car with burned up star specs through the snow and ice. It was scary as hell and I need to do something right away about it before it snows again/i die.
One of my navy buddies offered me a set of 4 215/45 17 winter tires(cant remember the brand) for 50$ and i immediately took him up on the offer. the only wheels i have are my na2 nsx wheels 17x7.5 and 17x9 and im wondering if it will be 'ok' to throw a 215 on the back. its obviously not ideal, and im not planning on driving it stupid.
I NEED MY ONLY VEHICLE TO NOT KILL ME THIS WINTER!!!! so heres my questions:
1. how dangerous is a stretched 215/45 on a 9 inch wheel?
2. once i install them, how do i tone down my suspension(kwv3's and whiteline front bar) to make the car easier to drive with this poor mans setup?
thanks guys. selling my s2000 is not an option until im either facing homelessness or starving. as i doubt i could get more than 9k for it. I have no bills, so as soon as i get worthwhile employment im back in the clear, i just need to keep it road worthy and NOT DIE
^Look for a set of tires and wheels on craigslist. I found a set of dunlop graspic ds3's on 7.5 inch wheels 215/55/16 used for 2 seassons with rims for 100$
Look hard enough and you'll find something for sure. In the mean time, I'd take the bus.
Also 215 on a 9 inch is a bit of a stretch but its been done.
You only have the nsx wheels? You don't happen to have the OEm wheels as well do you? You could run the nsx fronts on the rear and 2 oem 17x7's in front. They the tires won't be stretched. I think as long as you are extremely careful you could run those tires on your current wheels but I am talking absolutely NO vtec, no pulls etc. You need to drive like a 150 grandma. The other option is selling these tires or trading them for some AP1's and putting some snow tires on those.
To add, for driving in slick conditions such as snow/ice, you want a soft/pliable suspension to help maintain traction, it allows more forgiveness under your steering inputs as well as help transfer weight to the axel that needs it whether under acceleration or braking, obviously the car and suspension isnt ideal for this at all, but a couple things you can do to help is run all your comp/rebound damping settings to 0 and run a lower tire pressure, somewhere in the 15psi range depending on the tires/wheels used. You want some squat and movement out of the sidewall, and the more sidewall the better. If your running a 215 on a 9" I would recommend not running this low of pressure.
You are basically setting up the car the exact opposite as if you would normally for a dry/high speed performer. Look at a rally car chassis set up vs a road course car.
^15psi really O_o I was always under the impression that you run snow tires 3-4psi above normal tire pressure. I agree about adjusting the rebound setting to the softest though.
http://www.tirerack.com/winter/tech/...jsp?techid=168
I have stretched a 215 on 9's and 10's in the past on my vw. The 215 on a ten looks scary as it is a lot of stretch how ever on the nine it was very mild looking. i commute 60 miles a day on stretched tires and never once had a problem. Seeing as your in a bind i would go ahead and do it. The tire is not going to un-bead itself unless maybe you drift into a curb at just the right angle and high, but even then any tire could correct size or not.
But to answer your question 215/45 would be totally fine. It may not be the "proper" tire size but it will work.
