Another offset question (sorry)
Old May 15, 2008 | 10:25 AM
VtecSpool's Avatar
Default Another offset question (sorry)
I've searched, best info I found was that I would prolly have to run 205's in the front.
The car is drop with only s-techs, so it's not even that low.
Any help would be appreciated, thanks.
Old May 15, 2008 | 01:07 PM
WashabiS2K's Avatar
17x7.5 +30 will stick out quite a bit.. my works are 17x7.5 +35 and they already rub if I lower my car any more / go over hard dips. My front fenders are also slightly rolled. a 205 might be able to help since it will stretch a little bit. I am running 225's on mine.
Old May 15, 2008 | 01:09 PM
VtecSpool's Avatar
what size tires are you running in the front?
Old May 15, 2008 | 01:39 PM
AP2's Avatar
AP2
he said he has 225s but your best would be a 205/50 up front along with a roll and pull of the fenders. As for the rear I would do a 245/40 with rolled fenders and some camber.
Old May 15, 2008 | 07:54 PM
VtecSpool's Avatar
Ok, i've been considering a 205 serie tire in the front - and going with 245's in the rear since i'm currently on 255's.
the only way to add negative camber is by using camber plates correcto?
Old May 15, 2008 | 11:25 PM
VtecSpool's Avatar
So I researched a lil and read that the oem camber can be adjusted, so I guess i'll play with that....and go with a sticky 205/235 setup.
Old May 15, 2008 | 11:39 PM
Sinji's Avatar
i would suggest 215 and 245 tires for those sizes. they would fit with camber
Old May 16, 2008 | 02:40 AM
VtecSpool's Avatar
Thanks!
Old May 17, 2008 | 01:09 AM
VtecSpool's Avatar
Is there a low-offset wheel thread?
Old May 17, 2008 | 08:41 PM
tsanhd's Avatar
https://www.s2ki.com/forums/index.ph...ic=456737&st=0
there you go, go through it and read some of the stuff they talk about its helpful, you'll get a better idea and better understanding of what to do. It will work, just roll/shave your fender and get some camber. Theres a guy in that thread that does 17 x 8 18 and 17 x 9 22 its on page 21, and it looks good too. lol
RagingCheese
Feb 19, 2014 07:22 AM
B Ma
Nov 15, 2013 07:16 AM
lilmrtinnie
Nov 4, 2010 09:08 AM
rushinxpress
Mar 24, 2010 02:06 PM
Suki2Point2
Feb 26, 2010 06:50 PM
