another spacers question
my front wheels are 7.5 +48 and im looking to bring them out a bit. would a 3mm T1R spacer make them almost flush with my front fenders? or do i need something like a 5mm. and if im going with something so small do i really need extended studs and hub centric rings? i dont want to half ass anything but on a budget. can someone shed some light on this... thank you in advance s2ki
5mm is borderline, you will lose over 3 full turns on your lug nuts. A 3mm spacer should be super cheap and you won't need hub rings, it might be worth a try if you want a subtle change. You can use some washers to temporarily space out the wheel and see how much you want, but don't drive with them on.
