ap1 non staggered wheels
Is anyone here running ap1 rear wheels up front and if so did you bore out all four wheels to 70.3mm and rotating them or just leaving the fronts up front and the rears in the rear?
I'm assuming if you were running a square set up, that if you were to rotate them, you would (depending if you are lowered) rotate them with FR L to the BK R and vice versa. I believe that if you are on stock height, you would just rotate the FR L to the BK L and vice versa again. It could be the opposite though...I would wait to have others chime in.
I know how they rotate. I was wondering if anyone with a square set up on ap1 wheels were getting all 4 wheels bored out so they could be rotated. I guess what I'm getting at is it okay to bore out the the wheels to 70.3mm and put them in the back or is it recommended to just keep them at the stock bore and only have the front wheels bored out to fit.
TWF
May 10, 2012 09:45 AM
