S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   Wheels and Tires (https://www.s2ki.com/forums/wheels-tires-56/)
-   -   AP1vs CR Wheel Weight (https://www.s2ki.com/forums/wheels-tires-56/ap1vs-cr-wheel-weight-1021744/)
spessx May 11, 2013 05:08 PM
Hey guys,
I just changed out the stock AP1 wheels on my '01. I put on OEM CR wheels. Some of the reviews that I read before purchasing my wheels was that cars felt slower after the swap to the heavier wheels. I was concerned about this so I weighed the AP1 wheels with stock size tires mounted when I took them off and compared them to the CR wheels with stock size tire's mounteds. The weights were exactly the same on the front wheels and less than 1/2 lb difference on the back wheels. Also, the circumference of each was the same (so there's no effective gear ratio change).
The upside to this swap is that my car looks better (my opinion) and has wider rubber under it (215's in the front, 255's in the rear).
And no, it doesn't feel slower.
-s
01S2KSA May 12, 2013 04:14 AM
I did not feel the difference on being slower when I had the CRs mounted. You will notice that the AP1 will handle slightly better with the CR wheels. ;)
spessx May 12, 2013 04:27 AM
Yes. And thank you sir for selling me the wheels!
01S2KSA May 12, 2013 05:57 AM
:tipwink:
© 2026 MH Sub I, LLC dba Internet Brands
