Camber Degree Display
Old Apr 24, 2011 | 07:14 PM
sebringsilvers2000's Avatar
ive been told going over 3 degrees will really wear your tires fast, so i have mine at 3 degrees in the rear and .5 in the front. and yes there is definitely no need for a camber kit, i have a 2.5 inch drop and i think the stock adjustments could go up to 4 or more degrees, however the lower you go the more camber you can get. at 3.5 degrees its not going to be all that noticeable like it is in the example you showed above, the car in that picture probably has 6 or more degrees on camber
Old Apr 24, 2011 | 08:04 PM
it'S2klean's Avatar
Originally Posted by hrpfg2
no problem.
-3.5 and -3.7, something that small can not be detected by our eyes.
but I would recommend the least negative camber as possible for numbers of reasons. one of them you should really keep in mind, tire wear. My rears are only about 4 months old and the inside is done. (I don't drive aggressively at all)
I don't have any right now. I could possibly snap one tomorrow.
Damn i really dont like the sound of that lol...
f@#k....i like ur camber tho its just right...if not a little bit more.
Old Apr 24, 2011 | 08:08 PM
it'S2klean's Avatar
Im just on eibach springs so i def. have decent wheel gap left.
Could i see how yours look at 3 degrees?
Old Apr 25, 2011 | 10:10 AM
RedCelica's Avatar
Originally Posted by it'S2klean
Sweet! Thats what im looking for! Maybe a -3.7 i want it just a TOUCH more than that...maybe even a 4.0
Thanks alot for the help! You also saved me 160 bucks on a camber kit! Good to know that i can just do it stock!
U wudnt have another picture of the the wheel huh?
One like this?
that's just plain sad
Old Apr 25, 2011 | 10:24 AM
psychoazn's Avatar
no problem.
I run -3.3, and its very visible to me...
I can usually guesstimate camber give or take a degree if its on a flat surface.
Old Apr 25, 2011 | 12:01 PM
i dont have a rear view like requested before so this is the best i could find. just notice the slight difference between the angle of the BMW tires (which has 0 camber) and my tires. its more noticeable from a rear view
Old Apr 25, 2011 | 12:40 PM
it'S2klean's Avatar
Hmmm that looks slightly less agresive than -3.5
I just dont know if i have the kind of budget to be changing tires every 1,000 miles...
Old Apr 25, 2011 | 12:47 PM
Dcon67's Avatar
One like this?
Agreed. That car needs overfenders, less camber, and some correctly sized tires (275's?).
Old Apr 25, 2011 | 01:01 PM
it'S2klean's Avatar
Just a stretched tire and less offset if you ask me
Old Apr 25, 2011 | 02:11 PM
hrpfg2's Avatar
Originally Posted by psychoazn
Originally Posted by hrpfg2' timestamp='1303700567' post='20503234
no problem.
Sorry, I should had been more clear.
What I was trying to say was that we can't really tell different from -3.5 and -3.7.
Yes, -3.5 is very visible but not close to what is shown in the pic above.
