can 225 F 255 R fit?
hey guys, im wondering if 225 front and 255 rear will rub is i am on swift spec r springs and stock ap2v3 wheels? im not rolled no fender mods at all
It will fit. Be careful when exiting or entering areas where the suspension is compressed and the wheel is turned. Check your front liners often for any signs of rubbing.
I ran this setup on Eibach Pro Kit springs. Occasionally rubbed a fender button in the front. Usually, as Magna_Spawn noted, Entering driveways with a bump.
sorry to be off topic ( but i always wanted to know how everyone puts the picture of the s2000 on their post. underneath your every posting
You can do 225 F and 255 R with 1" drop without rubbing.
offtopic Step 1: You go to http://sigcreator.andrewjnuttall.com/s2k/ to create your photo/signature, then enter your username. Step 2: you go here https://www.s2ki.com/s2000/index.php...area=signature and copy paste the url you get from andrew above |
They do fit but I would run some more negative camber when you do the alignment. At stock height no issues at all. If I can help with the tires let me know.
