Can OEM front rim handle a 225 width Yok A032R?
Old Feb 26, 2003 | 04:37 PM
monkeymaker's Avatar
Default Can OEM front rim handle a 225 width Yok A032R?
Right now I use the A032Rs on my stock rims (for the racetrack only,) 205 front and 245 rear. I'm still at the stock ride height. The car's looser than I'd like on the track, so I'm about to buy a bigger front swaybar. In case the bar causes me to go from too much oversteer to an understeer condition, I might want to add some front grip with wider rubber, so can the OEM wheels take an A032R tire in the 225 size?
And for that matter, does anyone know if the A032R is available in a 255 or 265 size that will fit on the REAR stock wheels?
Old Feb 26, 2003 | 07:23 PM
Russ's Avatar
Yes, you can use either the 205/55/16 or 225/50/16. Both will fit on the stock 6.5-inch wheel. The largest sized Yoko race tire you'll be able to fit on the stock rears are 245/45/16. You COULD fit the 255/50/16 but the tire would be 25.9-inches tall. Not cool.
Old Feb 27, 2003 | 05:15 AM
Jim@tirerack's Avatar
Former Sponsor
You would want the 225/50R16 and 245/45R16 rear. This keeps the diameter correct for the car and the front to rear stagger about the same as well.
If I can help I have the tires in stock at 165.00 front and 168.00 rear.
Thank you
Jim 800-428-8355-364
FormulaStwoK
May 26, 2012 11:56 AM
Olegator
Apr 12, 2009 01:48 PM
pushin9
Jul 13, 2005 06:02 AM
john hood
Apr 28, 2004 12:23 PM
monkeymaker
Feb 27, 2003 06:20 AM
