Can someone help me find an offset?
Oz Alleggerita HLT
I'm checking out the Oz Alleggerita HLT in 17x7.5 (offset is not listed). Would it be safe to assume since the offset for 17x7 is +49mm, the et for 17x7.5 is close to 59/60? I'm basing this assumption off the fact the 17x8 rears are +48, and the 17x8.5 are +59. I'm thinking of running these w/Neo Advan AD08 FR 215/45/17, R 245/40/17 and need to know if the fronts have clearance. Searching off google yields really inconsistent figures so wondering if anyone can help me clarify fitment with this setup. If the offset for 17x7.5 is +48 (same as 17x7), i think the 215s will have minimal clearance, according to the wheel fitment guide. Thanks in advance! |
If you bring up the "black painted" wheels it shows the 7.5" offset as +48. You should be OK with a 215 on the front.
@ 1nate7
Woah, good catch! Thanks for the prompt answer. I hope this GPW/full red interior/gold rim look works out. If it doesn't.. oh well, i still have sick summer tires :D . ..and 15lb rims :thumbup: . |
if you go tire rack- make sure to check the hub rings- I just got the OZ allegarittas yesterday and they switched the rings by putting the rear rings on the front rims and vice versi. I'm using stock sizes BTW- and the anthracite finish looks good on Sebring Silver IMO.
@ ol rich
Thanks for the heads up. It's probably going to be a few months before I get these rims. Well, the first day it turns 60 degrees here in NYC, I'll be ordering them :D. That is, if it ever stops F@#king snowing. I hope this GPW/gold w/full red interior deal turns out well. I'm also considering red lugnuts for an accent but that's still a thought in process. Don't want to look too ricey :rolleyes:. What size wheels/tires did you go with? And how's the fitment? Also, when you get the chance, let me know how it affects your ride quality/handling for DD (if you're not running a dedicated track car). Thanks! |
| All times are GMT -8. The time now is 10:22 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
