CE 28 fitment issue
Old Sep 22, 2010 | 06:23 AM
llxzxll's Avatar
Default CE 28 fitment issue
I'm currently looking at a couple sets of CE28N's. I was told that both sets fit without any modification to the fenders. I know one is 100% plug and play, but I wanted to get your input on the other set.
Set 1: 17x7.5 +50, 17x9.0 +63
Set 2: 17x7.5 +48, 17x8.5 +50
Both are running 255/40 in the rear. I would like to purchase a set that would sit as flush as possible without modification, but if Set 2 would require any fender mods, I'd probably go with the first set.
Please help me out. I need to figure out which set to buy in a day or two.
Thanks for any help!
Old Sep 22, 2010 | 06:33 AM
punchdrunk's Avatar
Both will fit, but Set 1 is S2000 specific.
Old Sep 22, 2010 | 07:27 AM
llxzxll's Avatar
So the second set wouldn't require any modifications to my fenders?
Does the 0.5 inch on the rear wheel make much of a difference?
Old Sep 22, 2010 | 08:25 AM
Dreaming_S2k's Avatar
Set 1 is what I'd do based on what you're saying you want.
Old Sep 22, 2010 | 11:56 AM
s2k dre's Avatar
Both sets will fit without fender mods. As long as u run a 245/40 tire in the rear with a 8.5 +50offset.
Old Sep 22, 2010 | 12:57 PM
ungucpho's Avatar
the 9 +63 would sit 8 mm closer to the fender and the 8.5 +50 would sit 15mm closer to the fender.
i would want the 17x9 +54 offset and roll the rear fender
pics from gotuning
Old Sep 22, 2010 | 01:07 PM
llxzxll's Avatar
wouldn't the +50 sit closer to the fender than the +63?
Old Sep 22, 2010 | 01:08 PM
s2sik's Avatar
the 1st set is 7mm less from the fender and has a little more stretch.
you could still get away with running the second set without modifications depending on which brand tire is the 255, how stiff the suspension is set, and how low you are. worst case if you already havent, you can peel off the extra plastic lip for a little additional clearance in the rear
Old Sep 22, 2010 | 01:31 PM
llxzxll's Avatar
So the higher offset wheels sit more flush to the fenders?
Old Sep 22, 2010 | 02:31 PM
raymo19's Avatar
The higher the positive offset the more they tuck under the fenders. Less offset will move you more toward flush or hella flush.
