CG Front and Rear Flare Fitment
I currently have a set of CG front and rears on order along with some KW V3's. Not sure what drop I plan on yet but I know I obviously have to go pretty wide to fill in those flares. I have seen threads where people are running 18x10.5 et 20 and still needing spacers at least on the rear. What is the optimal specs to be running with these flares? Apologize if this has been discussed before I couldn't find a solid answer. Would like to avoid using spacers also.
I can't speak from personal experience, but just judging on how wide those rear flares are (+75mm) you could run a 11.5jj +0 with a 295 and clear without crazy camber. Again, this is the rear.
How wide are the front flares? +40-45mm?
I think I can help out!! One of our customers (highwaystardoritos) has a CG garage S2000 with Work Meister S1s.
Specs are this:
18x10.0 +5 Front
18x11.0 -8 Rear
Hopefully this gives you an idea. Also he is running some pretty think Toyo R888s.
Specs are this:
18x10.0 +5 Front
18x11.0 -8 Rear
