changing my offset
Old Dec 10, 2004 | 07:23 PM
s2kdarren's Avatar
^thank you for your advice and opinion......
keeping in mind the offset for this rim is 42... my fronts are 45 so i KNOW they can go to 45 still being safe....
but i dont think 45 is enough.....
Old Dec 10, 2004 | 07:28 PM
turbo_pwr's Avatar
I think you are forgetting the fact that when they are shaving it off they are changing the integrity/strength of the rim. At least that's what I've been told.
Old Dec 10, 2004 | 09:14 PM
s2kdarren's Avatar
more intense reasearch is needed so saftey doesnt become an issue
Old Dec 10, 2004 | 09:18 PM
l8brakr's Avatar
You're assuming they use the same mold for a wider rim and machine down the hub area to get the correct offset they want? Even using that logic (which is wrong) the wider wheel with more tire on it will have to withstand higher forces than the 7" wheel with smaller tires. Please do yourself a favor and don't let that goofy bastard touch your wheels while they are still sellable and get a different set or roll your fenders and maybe adjust your camber to give a little more clearance.
Old Dec 10, 2004 | 11:51 PM
Nobody's Avatar
You're not afraid of shaving off material from your rim, but you're afraid of rolling your fenders?????
Do yourself a favor--sell the rims to someone who owns a car the rims were made for and visit tirerack.com for a proper set.
Old Dec 10, 2004 | 11:54 PM
Hoenda's Avatar
safety should be your priority, esp in a high performance vehicle.
The 'offset adjuster' (better know in this thread as 'goofy bastard') may be trying to do you a favour, but he's not. Shaving off the load bearing surface and structure of the wheel is downright dangerous. Roll the fender or better still, get rims with better offsets, sorry for being repetitive.
peace.
Old Dec 11, 2004 | 03:13 AM
turbo_pwr's Avatar
too bad you don't live in NY. I'd roll your fender for free just so that you don't do the rim shaving.
Old Dec 11, 2004 | 05:16 AM
s2kdarren's Avatar
thanks guys
im not going to change the offset...
I am not going to roll the fenders either, I am running eibachs and only rub very little on large bumps in the ground... very bearable
Old Jan 9, 2006 | 03:28 PM
x s2k x's Avatar
Originally Posted by s2kdarren,Dec 11 2004, 06:16 AM
thanks guys
Your lucky that you even got your car lowered. Mine, I have 17x7.5 at the front and rears are 17x8.5 at the back... Offset is +40 for both. Don't really know what to do with them. I got sold a wrong offset for my car and having problems just making it work. Company has been claiming that they have done it with a lot of s2k but still haven't seen anybody rolling like that on the board. Right now, its not rubbing but dont know whats going to happen if I lower it 1/2 inch......
Old Jan 9, 2006 | 10:27 PM
ASMspec's Avatar
Originally Posted by s2kdarren,Dec 9 2004, 01:58 PM
I have racing sparco NT-R's 17x7 infront with a 45 offset and 17x8 42 offset in the rear..... as u know 42 is a low offset and rubs slightly on bumps So IM hoping maybe a local shop (they gave me some hope) that they can raise my offset a bit.....
my quesation is what offset would be the minum u guys would feel i can run (using a 245 tire) and would this effect anything in a very negitive way example........ is it safe to have a 50 offset rear and a 45 offset front... does that ruin the staggered setup???
sorry as i am not experienced int his area....
17x8 +42 is workable. You can run a 235/40/17 rear tire and go upto 2.5 inch drop if thats what your looking for. Yes you will loose CP. For daily driving/commuting its fine. 245s will rub. With extreme camber you could get away with it but ideally if your conservative then I would recommend/suggest going with another set of wheels.
