cr wheels and tires fit on ap1?
I recently purchased a set of cr rims (17') that take 215/45R17 in the front and 255/40R17 in the back. Will these fit on my 2001 ap1 s2k? I'm concerned about rubbing, since the ap1 oem tires are 205/55R16 in the front and 225/50R16 in the back. That's a significant difference in tire width, especially in the rear (about 1 inch wider).
Also, will the change in wheel and tires (assumably heavier) have an impact on the driving characteristics? If the handling is impacted, what tire sizes should I use to match my ap1 handling while using the cr wheels?
Any input/help is greatly appreciated.
As for tires, you can put a 225 in the front if you'd like.
The handling WILL be impacted, in a positive manner.
I sold my CR wheels to an AP1 owner too....
"215/45R17 in the front and 255/40R17 in the rears". That is my setup on my AP1 on CE28's with OEM offsets... they fit just fine.
I've done research about a 1 inch drop on these forums and apparently it shouldn't rub even then.
As far as handling is concerned i think there was a significant improvement in grip... and the wheels are lighter
