ebay wheel spacer
Does anybody ever put on ebay hubcentric wheel spacer. I was looking to get the 15 mm ones to put on my ap1 with ap2 v1 wheels and lowered on eibach pro kit.
I was wondering about the quality and the weith of these spacer. Can someone told me more about these? Thanks :hello: |
I bought a pair of these and a pair of "name brand" spacers... the ebay ones were better quality by far! I ran mine for about a year... had the wheels/spacer on and off the car 3 dozens times with no problems.
Thanks. With the price of a pair of kick s or H R, I can get both, the front and the rear of ebay ones.
Thanks for saving me that money. |
The biggest quality difference was the lugs... the lugs that come with the ebay ones are stout! The other ones I had wanted to strip... and I paid double for them. They also didnt match up to the hub perfectly, but the ebay ones did. Just be sure to get the proper hub-bore.
thanks for the advice. Do you know which hub bore should i get to fit the ap2 wheels?
Thank you |
Also, the seller write that the 15mm spacers are specific for the rear. I don t find any 15mm ones for the front. Do you know what s the difference(if there s one)between the font ones and the rear ones? Will they fit for both?
Front bore is bigger
Yes, front bore is larger... thats why I had to order a differenet manufacturers spacer for the front. Try emailing the selles and seeing if he has any that will fit the front bore of the S2000.
Thanks for all the answers. I ll do like you said and if he doesn t have any that fits for the front i ll just do like you did and order a set from another manufacturer.
I have a set of Volks Gtns 18" staggered (picture on my sig), I don't know what offset i have (anybody knows how to figure that out) does not "look" to be to much an aggressive offset, but is lower than OEM for sure but im sure not by much, that's why im looking into very small spacers maybe 3mm? Would you be able to tell the difference with 3mm?
found THESE on ebay, but not sure if its worth it??? what do you think? thanks :hello: |
