View Poll Results: whcih motor is better?...
Voters: 17. You may not vote on this poll
F20 vs. F22
They are pretty close to equil so it would not be worth the money to switch out motors. There reason they built the f22 is because americans like torque. They like brute power and not finness. There is a reason the rest of the world still has a f20 in there s2000s
(Ok 9000 reasons!)
Edit: Not sure why this is in tire and wheel forum?
(Ok 9000 reasons!) Edit: Not sure why this is in tire and wheel forum?
Your profile says you have an 06. You should already have the 2.2L engine, so no benefit from swapping for you.
Hmm why in the wheel and tire forum?
Lets see both sets of OEM tires on the AP1 and AP2 have about the same contact patches. I'd give the S02 a slight advantage in dry grip and the RE050 an advantage in wet traction. Both great OEM tires. Is this a trick question???
