S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   Wheels and Tires (https://www.s2ki.com/forums/wheels-tires-56/)
-   -   Factory alignment spec (https://www.s2ki.com/forums/wheels-tires-56/factory-alignment-spec-967510/)
ryce4u Jul 21, 2012 04:55 PM
Does anyone know the U.S. factory alignment spec for ap1 and ap2 ? I found the factory UK spec but having trouble finding the U.S spec . Thanks
fernando. Jul 21, 2012 05:07 PM
Top section is US, bottom is UK. :)
http://robrobinette.com/images/S2000...nt%20Specs.jpg
ryce4u Jul 21, 2012 05:27 PM
Ahhh thanks ! Did the spec change for ap2?
ZDan Jul 22, 2012 07:28 PM
Those specs are UK, first set is the range, 2nd set "recommended settings".
Unfortunately, their range for rear toe is absurdly, insanely, dangerously high, 2x higher vs the US range. IMO, it is in error. They recommend the lowest end of the range, or 0.67 degrees total, but this is still way too much imo. Poor handling, instability over bumps or in traction-challenged conditions, ridiculous wear rate, and worse mileage vs lower toe settings. I recommend 0.2 to 0.3 degrees total.
The uk recommended camber is fine, though.
ryce4u Jul 22, 2012 08:30 PM
I think i'm doing
Front
Caster Left 6.45"
Caster right 6.45"
Camber left -1"
Camber right -1"
Toe 0"
Rear
Camber left -2"
Camber right -2"
Toe left 0.15"
Toe right 0.15"
Does that sound good ? I'm lowered on koni yellow (lower perch) and eibach pro kit though. Not sure if they're going to be able to get this exactly . I'm mainly going to be daily driving this .
ryce4u Jul 22, 2012 08:33 PM
or should I do.... ?
rear
toe left 0.20"
toe right 0.20"
ZDan Jul 23, 2012 05:42 AM
Be careful with your units! Another think the UK spec got wrong was using (") instead of (') for arcminutes. (") is the symbol for arc*seconds*, which are 1/60th of an arcminute, 1/3600th of a degree.
In the US, most shops do not use arcminutes, but decimal degrees. Some shops still use inches for toe settings, for which the symbol is ", which is what erroneously appears all over the UK spec where they intended arcminutes but used the symbol for arcseconds.
What units does your shop use for toe settings? Decimal degrees, arcminutes (not likely), inches, or millimeters?
If you ask for 0.20" per side, that will be taken to mean zero point two inches, or 0.46 degrees per side, 0.92 degrees total. YIKES! Way way WAY way too much.
My recommendation for rear toe in decimal degrees:
0.10 to 0.20 degrees per side, or 0.20 to 0.30 degrees total
in inches ("):
0.044" to 0.066" (inches) per side, or 0.088" to 0.132" (inches) total
millimeters:
1.1 to 1.7mm per side, or 2.2 to 3.3mm total
arcminutes ('):
6' to 9' (arcminutes) per side, or 12' to 18' (arcminutes) total.
ZDan Jul 23, 2012 06:11 AM
Originally Posted by ryce4u (Post 21880836)
I think i'm doing
Front
Caster Left 6.45"
Caster right 6.45"
Here you must mean 6 degrees, 45 arcminutes. Not six point four five inches!
IMO, caster is overrated. I like less, actually. The range in the UK spec of 6 degrees +/-45 arcminutes translates to 5.25 to 6.75 degrees. You will be OK anywhere in that range, but my preference is toward the lower end. More gives heavier steering and more self-centering. Less gives lighter steering and less self-centering. Your preference within that range should be OK.
Camber left -1"
Camber right -1"
Damn UK spec! Should be DEGREES, not inches (or arcseconds).
Toe 0"
Same here. But zero is zero anyway...
Rear
Camber left -2"
Camber right -2"
Again, DEGREES, not inches or arcseconds.
ryce4u Jul 23, 2012 03:47 PM
Sorry, I meant for all of these # to be in degrees but couldn't find the symbol. Anyway, got my alignment done today and specs are
Told him to do this spec:
Front
camber -1.0 degree
caster 6.75 degree or (6 degree and 45 arcminute)
toe 0 total
Rear
camber -2.0 degree
toe 0.20 total
Here's the old and new specs afterward (he tried to get as close as he could to the specs I provided him):
Front left (PREVIOUS)
camber -1.1 degree
caster 6 degree
toe -0.39 degree
Front left (NEW)
camber -1.1 degree
caster 6.0 degree ( said this was the max)
toe 0.01 degree
Front right (PREVIOUS)
camber -1.0 degree
caster 6.1 degree
toe -0.39 degree
Front right (NEW)
camber -1.0 degree
caster 6.1 degree ( said this was the max )
toe 0.00 degree
Rear left ( PREVIOUS)
camber -2.4 degree
toe 0.61 degree
Rear left (NEW)
camber -2.1 degree
toe 0.11 degree
Rear right (PREVIOUS)
camber -2.6 degree
toe 0.60 degree
Rear right (NEW)
camber -2.3 degree
toe 0.10 degree
Impression: overall, I did notice a big difference. The car was overall more responsive to driver's input and more " agile " . I'm not sure why he wasn't able to adjust the caster from the previous setting though.
ryce4u Jul 23, 2012 03:49 PM
btw . Thanks ZDan :thumbup: !
© 2026 MH Sub I, LLC dba Internet Brands
