S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   Wheels and Tires (https://www.s2ki.com/forums/wheels-tires-56/)
-   -   Fender liner clips gone (https://www.s2ki.com/forums/wheels-tires-56/fender-liner-clips-gone-970091/)
Danwolski Aug 1, 2012 01:22 PM
So I got some new wider wheels. In the front I have 17*7.5 +45 with 225 tires in the front on stock suspension with -1.7 deg of camber. Today I noticed that the fender liners are missing the top 2 clips on both sides. Should I be worried about the wheels damaging the fenders? Also I want to replace the clips to keep the fender liner pressed against the fender, will they be ripped off again? Is there any other way to keep the liner pressed against the fender?
Here are some pics of what im talking about
https://i.imgur.com/lcEv8.jpg
https://i.imgur.com/4NX1n.jpg
Also im considering lowering it a inch with eibach springs. Will going that much lower damage the fenders? When you roll your fenders what do you do with the liner and these clips? And if I lower on eibach springs will I be able to get more camber? Like -2 to -3 deg?
cruc1a7 Aug 1, 2012 04:04 PM
You can trim the liners like they do with rolled fenders. If you trim them they will hold themselves up. My concern would be how close you are already coming to the fender with tires ripping clips off prior to the drop.
lltysonll Aug 1, 2012 05:13 PM
ebay sells them for cheap if you do decide to get more.
Danwolski Aug 1, 2012 05:14 PM
This is the clearance im getting on stock suspension. I dident expect to have those ripped off since I have a decent amount of wheel gap on stock suspension.
https://i.imgur.com/14274.jpg
https://i.imgur.com/774wB.jpg
XBMAX Aug 1, 2012 05:30 PM
This is simple solution, take the fender liners out, and roll your fenders,
Danwolski Aug 1, 2012 05:59 PM
Id like to keep the fender liners, can I trim this part off?
jst2878 Aug 1, 2012 06:10 PM
the drop mixed with offset and tire size will keep eating up you clips every big dip in the road.
clarkster009 Aug 1, 2012 06:22 PM
Two words: zip ties.
Danwolski Aug 1, 2012 06:53 PM
Its just a hole, how would I put them thru? I think id have to cut a hole in the liner
Danwolski Aug 1, 2012 06:55 PM
Do I risk damaging the fenders themselves? Im thinking rolling the fenders and having like -2 to -3 deg camber, will this prevent damage?
© 2026 MH Sub I, LLC dba Internet Brands
