S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   Wheels and Tires (https://www.s2ki.com/forums/wheels-tires-56/)
-   -   Fender roll? Spacers on AP2 wheels (https://www.s2ki.com/forums/wheels-tires-56/fender-roll-spacers-ap2-wheels-1212193/)
spooned_s2k Apr 27, 2022 07:22 AM
Hey all - just wanted some insight before I pull the trigger on spacers.
I understand 15mm is the smallest we can get with the built-in studs (I do not want to swap to longer studs to fit a 10mm etc.)
So I would love to do a 15mm x4 setup on my ap2 running ap2v2 wheels & 215 / 245 michelin pilot sport.
However, I am decently low (roughly 0 to .5 finger gap front and rear) - anyone know if this will fit without needing a roll? As I DO NOT want to roll.. maybe I'd have to raise slightly?
Any insight would be appreciated.
Shift9303 Apr 27, 2022 09:22 AM
I hope you mean to say that you're using spacers with built in studs.
In other regards this setup will require a roll, especially if you're as low as you are. You'd end up around 215+40 and 245+50 which is getting pretty aggressive. I'm running 255+50 all around and required a fender roll with bumper tab relocation at the rear even with -3.0* camber. Even if I was 5 mm narrower I don't see myself clearing the bumper tabs very easily. At the front the most aggressive people usually can get away with is 215+45 and even then that's a bit of a squeeze too.
spooned_s2k Apr 27, 2022 11:01 AM
Yes that is what I mean lol.
From your reply, it sounds like a 5-10mm would be more appropriate on this setup. However, obviously I would need to do the extended wheel studs for this instead of the spacer with the built-in studs.
Otherwise - seems like the other option is raise the car an inch or so, or just don't do the spacers at all
Shift9303 Apr 27, 2022 02:09 PM
On second thought 215+40/245+50 might clear but it's a grey area depending on height, tire, and camber. I think I had some of the numbers off in my head when I was typing the first response post. 215+40 is equivalent to 255+60 which is a semi common non stagger offset so you might be able to get away with it. 245+50 still looks really close by my eye ball when I look at my car and I think the rear bumper tab might still be an issue for it. But vaguely I remember people saying they've gotten away with 245+50 now. Either way you likely need to run at least -2.0* camber and probably closer to -3.0* camber optimally both front and back. This would be something I would try at your own risk but you might be able to get away with it.
B serious Apr 28, 2022 01:02 PM
You will need to roll them (or let the tire roll it for you?)
And be very careful on ingress/egress of driveways, with the wheels turned.
Manga_Spawn Apr 28, 2022 08:39 PM
It sounds like you are pretty low. I wouldn’t risk not having the fronts rolled. The rears you can address with some camber but the fronts are always much bigger risk for actual damage from a tire catching.
pnbcoolbreeze Apr 29, 2022 11:27 AM
I installed 20mm with OEM height. No need to roll and no rub.
Shift9303 Apr 29, 2022 11:37 AM
Pics? IDK but IMO that would look comical with the amount of poke and wheel gap at stock height. I ran 255 +57 at stock height and IMO that was bad enough already.
© 2026 MH Sub I, LLC dba Internet Brands
