Fender Roll on Spoon SW388's +35f/+45r
Hello my car is slammed and I was wondering if anyone could provide me with info on how much negative camber I need to run on these spoon wheels and how much of a fender roll is needed so the tires don't damage the fender? The front wheels are 16x7 +35 with 205/55/16 tire and rear wheels are on 225/50/16 tire. Please let me know all help is appreciated.
...................If I calculated it all correct then; rears would be no problem, fronts will be appox. 3mm past the fender. I believe there is more than 3mm of fender lip that you can roll, if not then a small degree of negative camber will do the job.
Originally Posted by GT Motoring,Aug 31 2009, 07:55 AM
have any pictures of where things currently sit? is the rear the same wheel size as well?
