S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   Wheels and Tires (https://www.s2ki.com/forums/wheels-tires-56/)
-   -   Fitment and lug nut question (https://www.s2ki.com/forums/wheels-tires-56/fitment-lug-nut-question-937993/)
RoninS2k Mar 18, 2012 05:02 PM
So just got these wheels, do I need to modify my fenders or anything else for proper fittment.
Also what kind of Lug nuts are good, can i use regular store bought one's or should i go out to get some better one's?
What are hub rings?
17x7.5 +49
17x9 +55
Dunlop Direzza 01 Star Specs 215/45-17 and 265/40-17
New to the tire/wheel thing
TIA
ungucpho Mar 18, 2012 09:48 PM
always roll your fenders. they might clear going straight down the highway, but they may not clear while you go up a steep driveway while turning
I would go with a 215/245 or 225/255. a 215/265 will have a thicker tire in the rear and might look funny
RoninS2k Mar 19, 2012 09:21 AM
Already have those tires..
They definitely stick out over the fender a bit, is that ok?
Anything else i need to run these? I read something about hub rings or something like that..
ungucpho Mar 19, 2012 09:40 AM
you don't really need hub rings.
AndrewLin Mar 19, 2012 06:16 PM
depending on the center bore of the wheel, you may need hubcentric rings to reduce vibrations at highway speeds
S2k007 Mar 19, 2012 09:59 PM
I'd get the hubcentric rings anyways for peace of mind. They're cheap.
© 2026 MH Sub I, LLC dba Internet Brands
