| s2000Junky |
Feb 4, 2013 11:19 PM |
You want an aggressive good looking stance that is functional, which doesn't give up tire to run. So in the +45-60 offset range depending on rim width and assuming you will be rolling or cutting the rear fenders. The front I feel like with proper alignment can be left alone and running pretty aggressive, the front rolling and pulling is something I try and stay away from when recommending wheel/tires, but if you know whats involved and willing to do it, you can get another 5-10mm of clearance depending on how far you want to take it. I don't know what size tires you might be solid on and I don't know all the TE options, but if it were me I would aim for a 245/35 up front on a 9" wheel +50 and a Rear 275-285/30 10-10.5" +50-60
