Front tires wearing on the inside
I have 10,000 miles on my car, and I was switching to Mobil1, and noticed that the front tires were wearing more on the inside than the outside. What should the tire pressure be, in the mornings when I havent driven the car, or the tires haven't warmed up. I am trying to determine, if the front tires are out of alignment, or if the tire pressure is not correct. Your help is much appreciated.
Andre |
It's normal.
At 10,000 miles I replaced my rear tires with OEM and had the front tires re-mounted as they were wearing on the inside.
I think this is normal if you do a lot of straight line driving. |
from postings here i understand that is normal too...
but mine wear on the outside and will not make it to 10,000 miles. i dont like slow turns! |
By a remount of tires, do you mean, taking them off the wheels in the front and switching left to right?
Andre |
You can dismount the tire from the rim and move them to the other side of the car. You can also take away a little negative camber in the front.
Jim |
i've notice the wearing on the inside too.
