S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   Wheels and Tires (https://www.s2ki.com/forums/wheels-tires-56/)
-   -   Help with comfortable tire choice (https://www.s2ki.com/forums/wheels-tires-56/help-comfortable-tire-choice-1176619/)
tremere613 Aug 16, 2017 08:52 PM
hey guys sorry for the post but I'm looking for a comfortable tire.. The best roads out here aren't really paved. Any recommendations?
1. Thoughts on continental sports?
2. Thoughts on a taller tire size? (So I can drive up my driveway without scraping)
Emil St-Hilaire Aug 17, 2017 05:05 AM
B.F.Goodrich All Terrain T/A.
rrounds Aug 17, 2017 11:06 AM
I run 235/45-17 up front with 245/45-17 out back on my stock '06. No mods to fenders, doesn't rub.
ROD
jsaric Aug 17, 2017 12:19 PM
check for bridgestone turanza if it is avaliable in this sizes.
i have conti sport 5 and it is 'comfortable' for a sports car
Manga_Spawn Aug 17, 2017 12:45 PM
Taller tire size can and will throw off your speedo. It can also have an effect on the handling of the car due to the added sidewall. Ride height should not be adjusted with tire size.
GSteg Aug 17, 2017 02:49 PM
I have Hankook Evo2 and I really like them for comfort. Would probably go with them again once they wear out.
Charper732 Aug 17, 2017 04:57 PM
If you run a wider tire then you will gain a little bit of height. I went to a 225 front and 255 rear contiextreme and the sidewall is a good bit taller than the 215-245s I was running. I noticed I scrap speed bumps a lot less. Plus with the taller sidewall, that will give the tire more flex, which will = a softer ride
zeroptzero Aug 18, 2017 05:49 PM
Consider a 16 inch rim if you can, the extra sidewall on the tires will be more comfy, I've got an ap1 with 16's, and I love my Bridgestone RE-11a's , they were out of production a while back but I found a new supply of them which was a pleasant surprise. I love the combination of tires and rim size.
Chuck S Aug 19, 2017 03:28 AM
With no information as to what car or wheels you have we can only guess at tires...
Comfortable tires on a S2000 are an oxymoron. The car demands rigid sidewalls if you want it to handle well. Honda went to 17" wheels in 2004 to get a lower profile tire.
Depending on what car you have you can fit alternate OEM springs, etc. to the car. The 2006 setup may be the most "comfortable" based on spring rates. The 2000 setup probably the worst (for "comfort").
The Honda engineers went to a lot of trouble to optimize the handling of this car -- including the OEM tires.
-- Chuck
osu1978 Aug 20, 2017 08:07 AM
I would just go with 225/255 if you are on AP2 rims. If you by chance are on the OEM RE050 tires just about every other replacement tire is going to be softer.
© 2026 MH Sub I, LLC dba Internet Brands
