S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   Wheels and Tires (https://www.s2ki.com/forums/wheels-tires-56/)
-   -   help on sizes!!!!!!!!!! (https://www.s2ki.com/forums/wheels-tires-56/help-sizes-111429/)
shogun Mar 19, 2003 07:57 AM
I was looking to run 18 inch rims on the front with a width 8 inches and an offset of 55. My tires would be 225/40-18. And on the rear also running 18 inch rims with a width of 10 inches at an offset of 74. The rear tires would be 285/30-18. Also i have the kg/mm springs which drop the car 35mm. Does anyone think that it would rub or if i would encounter any other sort of problems.
thanks
Jim@tirerack Mar 19, 2003 09:02 AM
I have heard of people running 285/30R18 on the rear but it is well outside our recommendation. On top of the fact that the 285 on the rear will really make the car push in corners. I think you would be better with the 265/35R18 on the rear. Hopefully someone will comment that has the 285/30 R18 in the rear.
Jim
ijumpman23 Mar 19, 2003 10:34 AM
I want some feedback on this too. What are the +/- of 285/30/18's??
© 2026 MH Sub I, LLC dba Internet Brands
