i need help about the offset
Old Aug 16, 2004 | 09:35 PM
lucki_dollar's Avatar
Unhappy i need help about the offset
[B] what is the best offset for 18x8 18x9 ? do you think 40 offset around is good or bad idea?
thanks
Old Aug 16, 2004 | 09:49 PM
Silver9k's Avatar
not offense to you, this is for the mods...
these are the kind of posts I am trying to save on with research from my post, here
https://www.s2ki.com/forums/index.php?showtopic=228382
And no, +40 offset is too small for 9" rear, especially if you are lowered...and its pushing it for the front...if your lowered...you would most likely rub with 8" +40
Old Aug 16, 2004 | 09:54 PM
Unhappy
what you meant by small? is it going to rub or not? that tires will inside the rear panels or outside?
thanks
Old Aug 16, 2004 | 10:13 PM
Silver9k's Avatar
with the lower offsets the wheel/tire is "pushed" further out and it would rub the fender...
Old Aug 16, 2004 | 10:15 PM
Silver9k's Avatar
Ohh...hmm I just realized you have an 04...I know they have a different suspension...and different wheels...but I'm not sure if the offsets should be the same or not, I would think they are?
04' owner...he needs help
Old Aug 17, 2004 | 06:47 AM
bazaar's Avatar
Try 62 front and 70 rear. I have 63 rear with a 10 inch wide rim and I wish I had the additional 7MM for clearance.
Old Aug 17, 2004 | 07:05 AM
Unhappy
so with your 10" wide, does it rub? do you have pic? i want to see it
thanks for your time
jon o
Aug 21, 2010 11:39 AM
rossco
Jul 3, 2009 11:12 AM
Mutlu
Oct 14, 2004 11:13 AM
Corleone
Oct 13, 2004 04:57 AM
LordMagnet
Jan 14, 2004 02:56 PM
