S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   Wheels and Tires (https://www.s2ki.com/forums/wheels-tires-56/)
-   -   i need help about the offset (https://www.s2ki.com/forums/wheels-tires-56/i-need-help-about-offset-228968/)
lucki_dollar Aug 16, 2004 09:35 PM
[B] what is the best offset for 18x8 18x9 ? do you think 40 offset around is good or bad idea?
thanks
:rolleyes:
Silver9k Aug 16, 2004 09:49 PM
not offense to you, this is for the mods...
these are the kind of posts I am trying to save on with research from my post, here
https://www.s2ki.com/forums/index.php?showtopic=228382
And no, +40 offset is too small for 9" rear, especially if you are lowered...and its pushing it for the front...if your lowered...you would most likely rub with 8" +40
lucki_dollar Aug 16, 2004 09:54 PM
what you meant by small? is it going to rub or not? that tires will inside the rear panels or outside?
thanks
Silver9k Aug 16, 2004 10:13 PM
with the lower offsets the wheel/tire is "pushed" further out and it would rub the fender...
Silver9k Aug 16, 2004 10:15 PM
Ohh...hmm I just realized you have an 04...I know they have a different suspension...and different wheels...but I'm not sure if the offsets should be the same or not, I would think they are?
04' owner...he needs help :D
bazaar Aug 17, 2004 06:47 AM
Try 62 front and 70 rear. I have 63 rear with a 10 inch wide rim and I wish I had the additional 7MM for clearance.
lucki_dollar Aug 17, 2004 07:05 AM
:) so with your 10" wide, does it rub? do you have pic? i want to see it
thanks for your time
© 2026 MH Sub I, LLC dba Internet Brands
