I think my rims are on incorrectly..
Old Aug 6, 2009 | 09:57 PM
jfs2000's Avatar
Default I think my rims are on incorrectly..
What happens if I bought my s2000 used and the front rims are on the back and the rear rims are on the front? Fronts tires right now are 245/40/17 and rear tires are 225/45/17. Is that bad for the car or bad for the handling?
Old Aug 6, 2009 | 10:26 PM
Mar48's Avatar
switch those asap it is definitely horrible for handling, you may want to make sure that the rims are swapped and not just the tires. (make sure the 245s are on the wider wheels and the 225s are on the narrower wheels)
Old Aug 6, 2009 | 11:02 PM
ftpsk8's Avatar
dont even want to know who owned that car before you.
Old Aug 6, 2009 | 11:32 PM
TRD_Celica's Avatar
wow yeah change those u, this can be very dangerous
Old Aug 7, 2009 | 12:11 AM
Volked_S's Avatar
unless you are daily driving backwards LOL
Old Aug 7, 2009 | 01:08 AM
mister x's Avatar
OEM rims? If so, the previous owner would've had to have bored out the rear rims to get them to fit on the front or run spacers. Wow, sounds really facked up. Scary.
Old Aug 7, 2009 | 03:08 AM
ZDan's Avatar
As mentioned above, swap them NOW (assuming that the wider *wheels* are in front).
You should be able to see if the mouting face of the wheel is flush with the mating face on the hub. The concern is that the rear wheels' center bore is smaller diameter than the fronts, so that the rears WILL NOT MOUNT CORRECTLY up front.
Very dangerous.
Old Aug 7, 2009 | 05:20 AM
1nate7's Avatar
If the tire shop mounted the tires on the wrong wheels, you will have to have them dismounted and fixed. It should be fairly obvious if you have a 245 on a 7" front wheel and a 225 on the 8.5" rear.
Old Aug 7, 2009 | 07:23 AM
MurderS2K's Avatar
LOL
WOW
who knows what else you are going to find on this car at this point
Old Aug 7, 2009 | 07:33 AM
jfs2000's Avatar
Well they arent the stock rims so I dont know if the width of the rims are different too. But the width of the tires are different so I guess ill correct it this weekend.
