input
Old Feb 24, 2010 | 08:13 PM
Silencer_F22's Avatar
Default input
i've asked a few people and have been getting different response? i want to run a 17x9 +30 rim all around and i wanna run a 245 in the back but i am not sure about the front. i some people say i should run a 225 and all i need is a roll, some people said i should use a 245 and just roll and add some camber but it will stick out if i'm not lowered. so my ? is what size tire should i use and what would be needed in order to prevent rubbing?
Old Feb 24, 2010 | 09:02 PM
JDMQuip's Avatar
Ummm...depending on your driving habits and such you can use either a 245 or a 225. If you're lowered more than an inch you're going to have some decent work to do to make them fit up front. The rears should be fine with a roll, and tabs relocated.
Old Feb 25, 2010 | 10:19 AM
Jim@tirerack's Avatar
Former Sponsor
I think you are goin gto need more thatn that to even make the rears fit. The wheels are 1/2" wider than stock and the offset is pushing the wheels out 35 mm further than stock. So basically your wheels are going toward your fenders about 1 1/2" more than stock.
The 225/45R17 is the smallest that is going to fit on the 17X9 wheel but they are going to be stretched and you will be outside the tire mfg's recommendation.
ragtophardtop
Mar 21, 2019 12:05 PM
TerminatioN
Jun 6, 2010 03:50 AM
@nthony
Jul 14, 2008 07:51 AM
lautll421
Apr 7, 2008 06:23 AM
marker20
Aug 2, 2007 06:27 PM
