S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   Wheels and Tires (https://www.s2ki.com/forums/wheels-tires-56/)
-   -   Issues with checking tire pressure. (https://www.s2ki.com/forums/wheels-tires-56/issues-checking-tire-pressure-619386/)
ae86pwr Aug 3, 2008 06:09 PM
I changed my tires yesterday to NT-01. When I tried to check my tire pressure this morning, my tire gauge was having trouble pushing down the valve pin. It turns out the tire shop used a bad valve stem core.
Solution: Went to Kragen and pick up a set of valve stem and take the valve stem core out as donor.
Check these pictures out.
https://cimg3.ibsrv.net/gimg/www.s2k...1bd993846f.png
bad valve stem core sits lower
bronze one is the bad one.
Silver one is the replacement stem I picked up at Kragen.
They "look" about the same, but the new one sits much closer to the surface.
AP2 Aug 3, 2008 07:29 PM
those bronze ones are known to go bad over time...i know at my shop we're not supposed to put those ones inside valves anymore.
ae86pwr Aug 3, 2008 10:57 PM
Probably that tire shop guy picked up a random one instead of reuse the one on my volk valve stem.
HUYS2200 Aug 3, 2008 11:17 PM
Running NT-01 now huh? :p
ae86pwr Aug 4, 2008 07:56 AM
Yeah RE-01R is too expensive LOL
Voodoo_S2K Aug 5, 2008 08:32 AM
Are you going to be daily driving with those tires on? If so, hopefully you don't end up heat cycling them to death.
© 2026 MH Sub I, LLC dba Internet Brands
