kt2 alloys
http://www.rimstyle.com/alloywheels/...ing_kt2_cup_ss
Im looking to fit these to my car, but I need an adaptor and the companies arent being very helpful. Does anyone know what adaptor I need for the s2?
Thanks
Simon
Thanks
Simon
Well that website sucks because it doesn't list the bolt pattern but I think I found it to be 5x130 which is not a bolt pattern I am familiar with. What you would need is a 5x130 to 5x114.3 adapter.The thing to pay attention to with the adapters is they are also a spacer so the offset of the wheel will be decreased meaning it will be harder to fit. I think it said the offset on these wheels is 52mm which gives you some room. If you can find adapters that are only 15mm thick you should still be ok with just a fender roll. If they are thicker that 15 you will have a harder time fitting the wheels as the offset will be in the low 30's.
I went on the wheel manufactures site which is in German but I found that wheel and the only bolt pattern that was listed was 5x130. It also listed the offset as 52. I would call whatever site you are looking at and talk to them. It is very odd that they don't list the specs of the wheels.
