Looking at RPF 1 wheels.
Old Sep 18, 2008 | 06:16 PM
shy_guyAP1's Avatar
Default Looking at RPF 1 wheels.
I'm thinking about buying a set of RPF1 wheels in this size:
F) 17x7.5 +48
R) 17x8 +45
Using the sticky about what will fit I'm under the impression that the fronts will fit a 215 and the rear will fit a 245 without sticking out. If I add 5mm spacers, would that give them a +53 and +50 offset respectively allowing me to run 225/255s? Or am I going in the wrong direction?
Old Sep 18, 2008 | 06:25 PM
Rich@Empower's Avatar
wrong direction.
Old Sep 18, 2008 | 06:26 PM
Nate4635's Avatar
Nope...wrong direction.
if you add 5 mm spacers it will push the offset lower, so..... +43 and +40.
And offset has nothing to do with the size tire that will fit on the rim - however some people run smaller tires (stretch) to fit an agressive (lower offset) setup.
Personally I'd opt for the 17x8 +45 17x9 +45 RPF1's, and you can run 225/255 with those....might have to modify your fenders a little though....245 might be safer for the rear.
mugen_kid's Avatar
I would go with a 17x9 +45 offset for the concave face in the rear. If you want a non aggressive setup go with what you stated above.
Old Sep 18, 2008 | 06:34 PM
shy_guyAP1's Avatar
Gotcha because it will move the contact point with the hub inward
I want something that won't stick out from the fender and will fit some rubber in there. I'm on stock suspension now, but I'm planning a conservative drop in addition to these wheels on DZ coilovers with 600lbs spring rates and koni yellows
Old Sep 18, 2008 | 06:55 PM
shy_guyAP1's Avatar
How would 17x7.5 +48 and 17x9 +45 be?
Old Sep 18, 2008 | 07:11 PM
sillyboybmxer's Avatar
that will be a very common and safe set up
Old Sep 18, 2008 | 07:25 PM
shy_guyAP1's Avatar
Would 225/255 tires stick out at all?
Old Sep 18, 2008 | 08:03 PM
dat boi's Avatar
if you go with 9+45 rears, you will more than likely have to roll your fenders when you drop the car. you should be okay with the fronts and 225
this is with 17x9+44 all around on stock fenders...you can see the rears sit flush with fenders on 255/40/17 falken azenis
Old Sep 19, 2008 | 03:58 AM
shy_guyAP1's Avatar
Those are the tires I'm planning on running too. Awesome fit btw
steve695
Apr 20, 2025 09:23 AM
steve695
Feb 24, 2016 01:57 PM
shox
Feb 26, 2007 08:25 AM
lude92_si
Aug 19, 2006 08:06 PM
toosteeley
Dec 3, 2003 12:52 PM
